High all.
A while ago I found a really good PDF conversion of the gunmage to the pathfinder system but I can't locate it here on the forums. Can someone help me find it or send it to me?
Cheers
Irish
High all.
Cheers
Irish
I believe the conversion you are talking about is on this topic somewhere:
http://privateerpressforums.com/show...ctive-thoughts
"Enemies you threaten make armies; Enemies you destroy makes graves." - Bayushi Tangen
i don't know if you have looked through the pathfinder book "ultimate combat", the one with the gunfighter class.
they have a wizzard archetype that uses guns, and it is pretty much a gunmage. very little tweaking would be necessary to make it a full blown gunmage.
If you guys are curious:
Paizo's Spellslinger
Personally, I don't like it. But does have a few similarities, though being a Wizard Archetype make me wonder if he is going to hit a shot at all.
i like it a lot. in our last campaign i almost made one but was instead relegated to the role of DM >.<
the only tweeks i would add are that arcane guns are just regular guns with runes inscribed in them, but all that jazz is gone once you get your hands on a magelock pistol.
and i don't see why a wizard would be bad at hitting things. you can stack on intelligence and dexterity after all...
The problem with almost any full CL gish build is that once you reach a certain level, the importance of the added shtick is getting less important, especially if its martial. Sure, the saving throw bonus will be neat (the to hit less so), but it has its risks and the four opposition schools really hurt. So definitely something that's better suited for multi-classing (or even just dipping, especially if the DM doesn't veto potential abuse).
Spellslinger/Gunslinger/Eldritch Knight might be okay. With more than the minimum one level of Gunslinger, it's probably more fun than the IK class.
The gunmage is in essence a 20 level Arcane Archer that uses a gun.
