Results 1 to 9 of 9
    Default Help me finally choose my first unit PLEASE
    This is mainly to do with budget restraints. My options are unfortunately limited to the following:
    Full unit of BBGR or min unit with Rengrave
    Full unit of Rev Crew or min with Rengrave
    Full unit of Black Orgun or Min and a solo like pistol wraith or WarWitch
    Min Mcthrall with Surgeon
    WSC and a solo like pistol wraith or WarWitch
    I will be using pDenny and i am working off a battle box, a min unit Bile Thrall and 2 Nightwretch.
    I know the pros and cons of pretty much all of the units...i just cant seem to decided. I tend to play for fun and no tournies. thanks.
    Destroyer of Worlds Deo85's Avatar
    I vote for Min Mcthrall with Surgeon though it would be better to at least make it a full unit if possible but I understand the need to keep your budget in range man. They hit hard enough to dish out on heavy jacks and with Denny they can hit infantry as well.
    Cryx are tough guys. Tough guys wear pink.
    Conqueror SjoerdH's Avatar
    Apr 2009
    Netherlands
    With pDenny? I would certainly go for the WSC and the PW. They add most to her.
    The mech thralls with the surgeon would be my second option.
    But however as you dont play tourneys the best would be to go what models you like best to field on the table. The ogruns are fun and you don't see them often. Denny can help with pulling the drags. So yes, they are fun
    get the WSC. they are so so good.
    Quote Originally Posted by philipcryx View Post
    Go with the WSC and a Warwitch
    Wither shadow would be a good first choice, especially since that's the option that comes with a Warwitch. Pistol Wraiths are good with Denny, but two is alot better than one.
    Annihilator GaspysInhaler's Avatar
    Sep 2009
    Pittsburgh, PA
    If you want a frontline melee unit to beef up your forces, go with the mechs + surgeon. They are pretty fragile, but hit hard, and keep coming back. pDenny can make them work quite well.
    If you want models that you will use with almost every single caster -- then get the Withershadow Combine and Siren immediately. They are fantastic and you will use them with almost every caster in almost every single game.
    Quote Originally Posted by shaner
    Also, our boners have neat abilities...they aren't little versions of our helljacks.
    or maybe those nyess hunters or croe's cutthroats?
    Feb 2012
    Örebro, Sweden
    Quote Originally Posted by zorrax View Post
    I agree with this. I upped my game significally since I got those.
