Can wolves of Orboros charge, roll to hit, use power swell and then roll to damage?
No, you cannot interrupt an attack to do something else. Once you've rolled to hit you need to roll for damage before you can do anything else.
This is correct.
Powerswell is an "anytime ability" as such it may be used at any time so long as it does not interupt a movement, an attack, or another action.
Furthermore remember that the attacks of each member of the unit must be resolved before moving to the next. So Wolf A must roll to hit, then damage, then resolve before Wolf B does the same.
how does this work with CMA? I will give the satyxis raiders as an example.
