    Conqueror Iixil's Avatar
    Enhanza
    Default 2 questions: extended control range/abomination
    ok il give examples here for clarity, first off...
    1. extended control range on the cryx stalker: "when checking to see if this model is in its controllers control area for focus allocation, double the area."
    i heard some one say that since the control range is doubled it would also benefit from double control range on a casters feat like say Pskarres blood magic, (pskarre being a 6 focus caster, the stalker is say 18 inches from pskarre after a charge and feat states "while in her control area etc") but it dosent look that way since it says "for focus allocation" is this true?
    2 abomination can affect friendly models: say the death jack with abomination is sitting around and a non fearless unit like blood witches pass through the abom zone and pass the check do they still continue their full movement? also if under Eskarres inspiration: "satyxis models/units in her control range never flee and immediately rally" do they finish their full movement or stop once the zone is entered? since it seems no command check should be made.
    More like a henchman Stevo's Avatar
    Iowa City, Iowa
    1. This ability has been modified in the Errata document. All effects that reference control area have their range doubled for Extended Control Range. The Errata document can be found here: http://privateerpress.com/warmachine...-errata-update
    2. You check when the unit has finished their movement, so after a charge, after an advance, after a run, or after a sprint/any other voluntary movement.
    In order to help with future searches by players regarding these rules issues, you should only ask one question in a given thread (unless the questions are very closely related). Hope this helps!
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats."
    -H.L. Mencken
    Quote Originally Posted by rydiafan View Post
    I saw a man be forced to eat a fleet marker in Diplomacy.
    Enhanza
    thanks but what about Eskarres inspiration? would the witches still be able to make attacks after the movement/abom encounter?
    Nov 2007
    Yes, Insipiration is the same wording as Fearless ability. You can effectively skip the command check for Abomination and they would act as normal.
    As rule mans a fool.
    When its hot he wants it cool,
    and when its cool he wants it hot,
    always wanting what is not.
