Results 1 to 10 of 10
    Oct 2011
    Default Trample and linear obstacles
    This came up in a game last night. Can a Warpwolf Stalker, with pathfinder, trample over a wall? Without pathfinder it's a definite no, but we weren't sure if this was different.
    Destroyer of Worlds wazatdingder's Avatar
    Lexington
    AFAIK, a wall does nothing to stop trample with or without pathfinder, unless you end on top of it.
    Oct 2011
    According to the rule on War Room: "It stops if it contacts a model with a medium or larger base, an obstacle, or an obstruction". I'd assume because a wall is a linear obstacle you'd stop, but I'd also assume that Pathfinder would let you ignore the wall.
    Pathfinder does let you move over low walls with your charges and power attacks.
    The description for this rule is on the Pathfinder entry itself, not the entry for terrain.
    Infernal Penguin Valander's Avatar
    Feb 2004
    Seattle, WA
    Quote Originally Posted by Prime, p.34
    Pathfinder - This model can advance through rough terrain (p. 86) without penalty and can charge and make slam and trample power attacks across obstacles
    Pathfinder allows trample over obstacles.
    Infernal from 30 September 2011 to 2 April 2014
    Destroyer of Worlds notsoevil's Avatar
    Nov 2003
    Curmudgeonville
    But a model trampling or charging over an obstacle (not a linear obstacle) still pays the penalty to move up said obstacle, correct?
    A ziggurat for example. Nothing in Pathfinder allows them to ignore the 1" up movement penalty, correct?
    Not that I play with ziggurats often, but I was wondering about this recently.
    Feb 2009
    Nuremberg, Germany
    Quote Originally Posted by notsoevil View Post
    That's correct.
    Linear obstacles state that non-charging advancing models can cross it at no penalty. The question is if that applies to a slamming/trampling model. Both abilities state that anything that prevents a model from charging also blocks those abilities. They don't mention being treated as charges in any other way, so it seems like a linear obstacle would not stop them - it's not an effect that prevents charging, it's an effect which stops charge movement, so with a strict interpretation of the rules you can both slam and trample over a linear obstacle. This is subject to infernal ruling, of course.
    This all assumes no pathfinder. If you have pathfinder, even charges aren't stopped by linear obstacles so tramples and slams would be fine.
    Apr 2006
    Denmark
    Quote Originally Posted by Sheer_Falacy View Post
    Pathfinder would not include a wording that says you can "slam and trample across linear obstacle" if you could do so without pathfinder as well. So you need Pathfinder (or something like it, Ghostly for instance) if you want to charge, slam or trample across linear obstacles.
    Feb 2004
    Seattle, WA
    Not subject to an infernal ruling, subject to the rule book:
    Quote Originally Posted by Prime, p.55
    It stops if it contacts a model with a medium or larger base, an obstacle, or an obstruction.
    That is from the trample rules. Similar is present for slams.
    Quote Originally Posted by Prime, p. 87
    An obstacle up to 1 ̋ tall but less than 1 ̋ thick, such as a wall or hedge, is a linear obstacle.
    Linear Obstacles are a sub-type of Obstacles.
    So, strict interpretation of the rules, you cannot slam or trample (or charge) over linear obstacles without an ability that allows you to do so.
