Results 1 to 9 of 9
Thread: pStryker help
    Default pStryker help
    I was looking into starting warmachine. I noticed there is a new plastic battle group set for cygnar. What would I have to add to the cygnar battle set to make it work/ competative at 35 points.
    I think it has Stryker, Ironclad, Charger and a Lancer.
    Destroyer of Worlds Dino-Czar's Avatar
    Later on
    It does, and that is a great core to build on.
    A melee and ranged unit would be great for you, followed by a Squire and some support solos.
    Try out Longgunners, Precursor Knights with UA, a Squire and Arlan Strangeways. That should give you a solid list to start off with.
    what is the squire? a journymen warcaster?
    Later on
    min sized long gunners/ knights?
    Annihilator thesavage's Avatar
    Sep 2009
    South Florida
    Also, take a look at Rangers and the Black 13th. They are really good, and the work well together. 9 points well spent.
    Later on
    Max both units.
    I know it doesn't look all fancy, but the stuff I suggested is going to be dead solid against the majority of things you're likely to come up against.
    Annihilator Tommeh's Avatar
    Apr 2005
    Houthalen, Belgium
    While not strictly in faction, Nyss hunters are a nice option too. Filling both the ranged slot, and in a pinch, the melee one as well.
    North Carolina
    Stormblades go well with Stryker, and make a good unit to cast Arcane Shield on. Precursor Knights make a good second melee unit (you can't cast Arcane Shield on them). Add Long Gunners (full) or Gun Mages for a ranged unit.
